А что сейчас можно тюнчить и корчевать?
Что бы еще прикрутить
кандидаты:
GT
10
7%
147
6
4%
156
19
14%
75
38
28%
Эва/Грал
11
8%
FIAT 500 Abarth
12
9%
Punto GT
5
4%
Таз/Subaru и прочие VW
25
18%
Тот самый Лексус
12
9%
Всего голосов : 138
Re: А что сейчас можно тюнчить и корчевать?
Сообщение Typhoon » Чт авг 01, 2013 3:10 pm
Morten Ruud’s Alfa Romeo GTV 617WHP
Engine:
Alfa Romeo 3.2L 24V V6 from an Alfa Romeo 147 GTA (FWD), modified sump/oil pan from a 2.5l12v V6, standard heads, standard camshafts, Spesso Racing headgaskets, CP pistons with 8.5:1 static compression ratio, H-beam conrods from PO in Poland, custom intake and exhaust manifolds, Comp Turbo CT3B 62-67 with T4 exhaust housing, TiAL 44mm wastegate, Accusump oil accumulator for steady oil pressure in long turns and braking/acceleration, Autronic SM4 engine management system, VW coils, 800cc injectors, 2x Bosch 044 fuel pumps, Facet fuel pump for catch tank, Griffin aluminium radiator mounted in rear, Davies Craig dual electric waterpumps, big intercooler in front
Driveline:
Sequential straight-cut gearbox from Sellholm Tuning in Sweden, Drenth gearset from Holland, diff housing from Volvo s90, LSD from Sellholm Tuning, custom made shafts with motorsport CV joints from GKN Driveline, gearbox and diff mounted in rear as standard
Suspension:
Adjustable Intrax coiloves on all four corners, custom made sway/roll bars front and back, custom made upper and lower A arms in front, Volvo V70/S80 uprights, fully adjustable for castor and camber, modified DeDion rear suspension with 3 degrees of negative camber
Brakes:
Front 4-piston Alcon callipers on 330mm discs, Ferodo DS3000R or DS Uno pads, rear discs moved from gearbox to wheels for easier access, 6-piston XYZ callipers on 330mm discs, hydraulic handbrake, Tilton pedalbox
Wheels/Tyres:
17×9-inch OZ Racing wheels, Michelin racing slicks 24/610-17 S8C or Toyo R888 if they tyres have to be road legal
Exterior:
Fibreglass front wings from Alfapanels in the UK, fibreglass rear wheel arches from PBC Composit in Sweden, Lexan windows
Interior:
OMP seat, steering wheel and harness, Racepak IQ3 dashlogger, digital gear indicator and AFR display, adjustable electric power steering
http://www.speedhunters.com/2013/07/gre ... romeo-gtv/
Сообщение yura piter » Чт авг 01, 2013 3:23 pm
судя по непиленому тоннелю коробка осталась родная,ещё как я понял сзади сдвоенные тормоза и на коробке и в ступицах установили.логично было бы поставить и спереди 6ти поршневые тогда...или при такой массе хватает 4х поршневых на треке?судя по впуску с GTA двигателя сняли лошадей 400-450?
очень интересная кольцевая машина получилась!
yura piter
Гоголевед
Авто: alfa 90
Сообщение zopuh » Чт авг 01, 2013 3:27 pm
Typhoon писал(а):Изображение
вот это влажный сон мечта мыловода - наддувателя свинспарка :D
подпись под сообщениями
zopuh
мотолог
Сообщение yura piter » Чт авг 01, 2013 3:30 pm
при чём тут твинспарк?
yura piter
Гоголевед
Авто: alfa 90
Сообщение _Lonely_ » Чт авг 01, 2013 3:34 pm
yura piter писал(а):при чём тут твинспарк?
да при том, что очень хочется. но получается только с V6 %)
L&C2A
_Lonely_
Авто: alba nelle Alpi
Сообщение Typhoon » Чт авг 01, 2013 3:41 pm
yura piter писал(а):судя по непиленому тоннелю коробка осталась родная,ещё как я понял сзади сдвоенные тормоза и на коробке и в ступицах установили.логично было бы поставить и спереди 6ти поршневые тогда...или при такой массе хватает 4х поршневых на треке?судя по впуску с GTA двигателя сняли лошадей 400-450?
Описание подробное железа всё есть внизу под фотами, коробка секвентальная, мощность 617лс с колес.
Сообщение Gundesvan » Чт авг 01, 2013 3:59 pm
Какой вкусный проект.
Смотрю места в ГТВ не особо много. Радиатор пришлось в багажник ставить :shock:
Весьма спорно воздух забирается на него :what
Сообщение cоlombо » Чт авг 01, 2013 3:59 pm
А что мешало поставить коробку от 944?
Сообщение Gundesvan » Чт авг 01, 2013 4:04 pm
Тогда уж от корвета. Он вроде тоже транзаксель, и момент гарантированно держит.
Сообщение Typhoon » Чт авг 01, 2013 4:06 pm
Я не понял, вы все советуете уже построенному и вваливающему проекту, какую КПП ставить? )))
Сообщение Gundesvan » Чт авг 01, 2013 4:13 pm
эх... нужно было флуд начинать с HEMI)))
Сообщение romcon » Вт авг 06, 2013 12:32 am
да пох ваши литражи. по крайней мере у нас в раше ни одна ваша гта не обьедет сраный тс славана или мой-это вызов господа гта-шники.ждём-с предложений :smt006
romcon
Авто: gtv.punto2. 156sw
Сообщение Gundesvan » Вт авг 06, 2013 1:24 am
на форуме кстати есть достойный экземпляр 156 с "непростым" Бассо :wink:
Сообщение Йож » Вт авг 06, 2013 10:00 am
romcon писал(а):да пох ваши литражи. по крайней мере у нас в раше ни одна ваша гта не обьедет сраный тс славана или мой-это вызов господа гта-шники.ждём-с предложений :smt006
А у тебя какое время на Полигоне или в Мячково?
Йож
Боевой Йож-разведчег
Авто: GTV 3.0
Сообщение Montekki » Вт авг 06, 2013 11:30 am
Gundesvan писал(а):на форуме кстати есть достойный экземпляр 156 с "непростым" Бассо :wink:
И где можно про него почитать?
Вернуться в Alfa Tuning
