Ferrari F430 will debut at Paris Motor show
Сообщение Vit155 » Вт авг 24, 2004 11:49 pm
The F430 signals the arrival of a brand new generation of Ferrari 8-cylinder models. This new car takes Ferrari's extraordinary achievements with aluminium technology, begun with the 360 Modena, to a whole new level, and offers a series of extremely significant innovations directly derived from the Ferrari Formula 1 single-seaters. Two of these innovations are world firsts for production cars: the electronic differential (E-Diff) and the steering wheel-mounted switch (better known to the Formula 1 Scuderia's drivers as "manettino"), which manages the integrated systems governing vehicle dynamics.
The other main characteristics of the new F430 are its light, compact 4,300 cc 90° V8 engine, which punches out 490 hp to achieve a specific output of 114 hp/litre, also providing the new Ferrari berlinetta with a weight-to-power ratio of 2.8 kg/hp (dry weight); a braking system with carbon-ceramic discs for optimal efficiency under extreme use (optional); a Formula 1-derived gearbox that cuts gear shifting times down to 150 milliseconds allowing the driver to make the very most of this truly high performance car (0-62 mph acceleration in 4 seconds flat, a top speed in excess of 196 mph) and an aerodynamic design that embodies the very latest competition technologies, specifically the flat underbody and large rear diffuser to increase downforce.
The car will be officially presented during the Paris Motor show in September 2004.
The UK price and specification for the F430 will be announced prior to its UK launch in 2005.
F430 - Technical Specifications
Dimensions
Overall length: 4512 mm 176.6 in
Overall width: 1923 mm 75.7 in
Height: 1214 mm 47.8 in
Wheelbase: 2600 mm 102.3 in
Front track: 1669 mm 65.7 in
Rear track: 1616 mm 63.6 in
Kerb weight: 1450 kg 3197 lb
Engine
Type: 90° V8
Bore/stroke: 92 mm x 81 mm 3.50 x 3.03 cu in
Unit displacement: 538.5 cc 32.86 cu in
Total displacement: 4,308 cc 262.89 cu in
Compression ratio: 11.3:1
Maximum power: 360.4 kW (490 CV*) at 8500 rpm
Maximum torque: 465 Nm (47.4 kgm or 343 lbft) at 5250 rpm
Specific horse power: 114 CV*/l
Performance
Maximum speed: >315 km/h > 196 mph
0-100 km/h (0-62 mph): 4.0 s
* For reasons of homogeneity, engine power is expressed in kW, in accordance with the International Systems of Units (SI), and CV (cavalli = horse power). The brake horse power (bhp) can be calculated as follows: 1kW = 1.34 bhp.
Сообщение Typhoon » Ср авг 25, 2004 12:53 am
:idea:
Зверь! Красота!
Сообщение Babai » Ср авг 25, 2004 10:00 am
А больше всего мне понравилась бибикалка на руле :)))
Babai
Авто: 155Q4 & G ti s
Сообщение Solo » Ср авг 25, 2004 2:13 pm
ФОТОШОП! :!:
или 3D-MAX :)
интерьер какой-то компьютерный...
Явно б/у счетчик пробега 88880
:lol:
А вот желтая шкала тахометра с коником понравилась!
Solo
Авто: 2002 Alfa 156 SW JTD
Сообщение Emir » Чт авг 26, 2004 6:26 pm
По рулю: Бибикалку понял, Engine Start тоже, ну а справа что?????? Что за тумблер??????
Alfa 147
Emir
Сообщение Гость » Вт сен 07, 2004 8:43 pm
Куда делась коробка... ???
Она что-автомат?
... и пидали какие-то странные (две всего). :roll:
Вобщем для дечёнок! :?
Гость
Сообщение Opelevod » Ср сен 08, 2004 9:28 am
Народ, а скока такой руль может стоить? :roll: :oops: :D :D ... и есть ли переходник на 33-ю? :D
Феррари стали слишком скруглять углы... мне не нравиться... а руль просто МЕГАклассный!
Opelevod
Сообщение zen » Ср сен 08, 2004 11:01 am
переключение передач на руле, вернее под ним, коробка "Formula 1-derived gearbox that cuts gear shifting times down to 150 milliseconds". А тумблер - это перключатель режимов коробки.
zen
Коллекционер
Сообщение Babai » Ср сен 08, 2004 2:03 pm
Интересно будет посмотреть на девчёнку, которая будет дёргать такие передачи :twisted:
Babai
Сообщение DimaAR164 » Чт сен 09, 2004 11:50 am
а мне тоже руль понравился очччччень :!: и кнопка такая красная- класная вот бы себе такую, фетишь на всю жизть :!:
DimaAR164
Вернуться в Ferrari
